Sport Truck Shootout, Bowling Green KY
AnniesSS
Ok... year three is on the calendar! :fume:
http://www.sporttruckshootout.com/
The Sport Truck Shootout is sponsored by the North American Truck Club www.454ss.com and this is to be our third year holding our event at the Beech Bend Raceway Park in Bowling Green, KY.
All trucks are invited - Stock, slammed, lowriders, 4x4s, classics. Events are being planned around the main event on Saturday August 2, including the Corvette Museum, Corvette Assembly plant, Fort Wayne, IN Assembly Plant, and possibly a few others that are in the works.
Please visit our site for more information and to sign up!!! :D
  • 4 weeks later...
I certainly hope some of you can get out and have some fun.. meet some great people... and talk trucks!!! :smash:
  • 3 weeks later...
Hey guys.... I hope to see some of you guys at the Shootout - and possibly at the Pre-Shootout events..... Ft Wayne Truck Plant.... Allison Transmissions.... Quick Fuel Technologies....
Thanks,
Annie :confused:
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,244 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
