2003 6.0L 2500 4wd Stalling at complete stop only?
I did my main oil seal, pan, pressure switch and rear freeze plugs, rebuilt the transfer case etc. 2 wks later I slapped it back together and she wouldn't even crank, I had a dirty NSS connection, changed the 2 connectors and switch and she fired right up. Now she run great 0 to 60 I cant feel any shifting just smooth right thru but when I come to a stop it stalls. During my evaluation before take down the wires on the VSS input were exposed right at the connector when I was sizing up this job I crossed and touched those wires with battery still connected, oops!I liquid taped the wire but I suspect it fried the sensor? What symptoms come from a faulty VSS input sensor or connection? Thanks fellas?
It should be throwing a code regarding the VSS if it is inop or not responding.
What kind of codes ya got?
No codes
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 685 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
