Truck missing, Showing Random/multiple cylinder misfire
I'm new to this but I really need help. I have a 2010 chevy silverado 1500 5.3 with 43,659 miles. The check engine light is on and shows a P0300 which is random/multiple cylinder misfire, and a code P219A and P219B which is mixture control bank 1 and 2, value out of range. I have changed all o2 sensors, new plugs and wires and I'm just lost. Would really love some guidance. If anybody has some ideas I would really appreciate it. I really don't want to go to dealership if I can fix it myself. Thanks.
Check fuel pressure first. Check for vacuum leaks. Plug a scanner in and look at the fuel trims. Is the computer dumping a bunch of extra fuel in to compensate for non-metered air?
do the easy stuff first before changing more parts.
Do some google research on the P219A & B codes. Go to alldatadiy.com get a subscription for your rig and see if they have a troubleshooting guide.
  • 1 month later...
Ok just a little update. I checked fuel pressure and it is good. I done a smoke test and found no leaks. It is only missing a idle but missing pretty bad. You can see the motor shaking. I can't really find anything online about the P219A and P219B that is any help. I don't have a scanner to do a fuel trim test. So I guess the update is I still haven't figured this out. Any more help would be really awsome. It's starting to get annoying. Thanks in advance for any help.
    bellssn690
    bellssn690
  • Who's Online   1 Member, 0 Anonymous, 706 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
