U-Guard floor liners
smurfy71
I have been looking for a set of floor liners for my 2016 Crew Cab, and have read some poor reviews for the W/T liners for this particular model of truck. I have found a Canadian manufacturer and was wondering if anyone here has any experience with them, 3D Maxdura? I have read some good reviews for other makes of trucks but haven't seen anything for GM's.
http://uguardautomotive.com/floor-liners/3dmaxdura-heavy-duty-floor-mats/
    • *Your
    • I'd guess that it's because they are Mann-Hummel filters since about 2016, they own Wix and are mostly all made in China now.
