Best Light Temp Combo hi/lo
what is the best bulb temp for headlights. Hi's and lo's???
what do you think about the headlights that jpcustoms.com sells on there webpage???
what about running lamps???
Could have used some more specifics, but here we go:
1. What is the best bulb temp for headlights. Hi's and lo's??? - First of all, it shouldn't matter between Hi and Lo beam. Good light is good light. If we're talking about color temperature of the bulbs, I tend to prefer 4300K or 5000K. Anything above that and the light is more blue/purple than white. To get to these temperatures, you're gonna have to go to HIDs. The typical halogen just can't do it.
2. What do you think about the headlights that jpcustoms.com sells on there webpage??? - I've installed both the Xenarc HID Auxiliary Low Beam Kit and the HID Chevy Upgrade Lighting Systems. The Chevy upgrade is quite possibly the easiest installation I have ever done. The Auxilaries require more work. Both products are fantastic, however, a little redundant on the same vehicle. If you're looking at the factory foglamps, they're weak. They have 27W bulbs that couldn't serve as a booklight (slightly exaggerated)
3. What about running lamps??? - If you're talking about DRLs (daytime running lamps), they're not worth upgrading. They're job is to highlight the fact you're on the road. The factory DRLs accomplish this well. If you're talking about fog lamps, there's not much you can do with the factory setup. If you install a higher wattage bulb, the plastic housings tend to melt from the added heat. There are plenty of aftermarket lamps that can be installed in that location.
  • 3 weeks later...
One more tidbit: I may have to take back what I said about the factory fog lamp assemblies. Someone mentioned on this board or another, that Sylvania is just coming out with a replacement bulb within their Silverstar lineup. Since those badboys are relatively cheap, you may want to try them out before switching out the assembly. The Silverstars, in my opinion, are the best 'bang for your buck' lighting upgrade out there.
