07 Chevy Avalanche P1682
hthy
Hi every one,
I have a 07 Avalanche with P1682,
Checked the power train relay & crank relay both work but the starter relay have no signal from ECM but the wire is good.
The security light always on.
Can somebody help?
Thanks
That's an ignition switch as far as I've seen
Sent from my Z981 using Tapatalk
Very common and very easy fix.
Not that I'm aware never had to on the Malibu impala Pontiac's
It's the same set up for the most part
  • 3 years later...
Check the aor bag module under carper under drivers sear. Unplug it. Water damage causes ground to short without blowing fuse. Shorts out bcm
    appletrav
    appletrav
  • Who's Online   2 Members, 1 Anonymous, 330 Guests (See full list)
