6.2 Diesel Like a rock
Nice pic! Makes you wonder if that guy is standing on the running boards for additional weight upfront. :cheers:
I'm impressed. The 6.2s suck though.
Yeah, some do but my brother has one in his company truck with 245k with minimal problems. No power, but it keeps on going.
That's what I was thinking! I wonder what the tongue weight was...
that's one heavy duty hitch he must have on there and if it's on the bumper then i want one of those bumpers
I don't think they even have the jack on the trailer all the way up yet.
Sometimes you get lucky with a crappy engine and you get a good one. Isn't that retiredmarine's truck from PUTC?
That 6.2 is one strong motor. I got one in my 87 chevy company truck along with a 3 speed tranny with a granny gear. Let me tell ya, shes no road runner, but no matter how hard you hammer on it, she loves it. I take it up the highway every day at speeds of 60 or so mph. Takes a good hill to get it to get it to that speed but it gets there. Sounds like the motor is gonna jump through the hood!! 220K and no major repairs, clutch, oil changes and fuel filters, thats it
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,262 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
