Pioneer heat sink hot
How hot is too hot for a heat sink? I'm hooking up an aftermarket pioneer radio in my 01 Silverado. I have a single cab, so there's 4 factory speakers. But, I wired up 2 additional speakers (not subs) behind the middle seat. They were out of a Cadillac, same plug as my speakers, same resistance (4 ohm). I used the right gauge wire to run to them
The radio is hooked up and working great, but the heat sink gets real hot. I can't touch it for more than a few seconds. Is this normal?
Pretty sure it is. Last alpine I had used fans and it was warm back there.
My new pioneer is like yours with a heat sink and it gets pretty warm. Been running that radio for 2 months now without issue including two 7 hour drives.
Installed on my 06 Avalanche.
Ok, sounds good. It's just crazy that I can't touch it for more than like 2 seconds. There's nothing really back behind it that I think would catch fire easily, and if I hold my finger close to it, almost touching it, there's not much heat emanating from it, it's just when you press on it
I popped the radio in and the heat sink is definitely against some wires. I tried my best, there's no getting around it. I hope I don't have a fire
Same thoughts crossed my mind.
Some wires are defiantly against mine as well.
Only time will tell.
If you pop out the heat and fan controls under the radio, you can pull the radio wires down there. After a while I figured that out. There shouldn't be anything against my heatsink now, but still makes me nervous with all the heat
    bellssn690
    bellssn690
  • Who's Online   1 Member, 0 Anonymous, 817 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
