R & D Controller Coming Out ASAP
I have been having trouble with the headlights cutting out when I tilt the wheel so I took the column covers off to see if I could find the trouble. Any way the problem was that the wires that go into the turn signal control that are the headlight wires (high/low beam) are FRIED. The extra draw from the headlight controller have melted the wires. Yes I do use the high beams alot, but not that much. I have seen posts for the Kenedy controller that changes the wiring configuration of the lights and will be switching to that. Lucky the dash didn't catch on fire. So, all you guys with the R & D Controller, I would take a look at the back of the dimmer control to see if your wires are getting hot. BTW the plug at the back of the turn signal was also noticably melted. :puke:
    hotfish
    hotfish
  • Who's Online   6 Members, 0 Anonymous, 659 Guests (See full list)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
