SuperMaxx header package available for 6.0 soon!
The 4.8/5.3 header package is available and the one for the 6.0 trucks should be ready to ship in a few weeks. We are currently taking orders for this package and will ship as soon as they arrive. You can also order the headers by themselves and cut/weld them to your stock Y-pipe.
115-841300 - 2000-'03 5.3 Truck / SUV - 1500 series 2WD & 4WD pickups, Avalanche, Suburban, Tahoe and Yukon
115-841350 - 2000-'03 6.0 2500 series 2WD & 4WD pickups and Suburbans, Escalade, Denali and H2
115-841310 - 2000-'03 4.8, 5.3 and 6.0 Chevy/GMC 1500 SUV*
(*Avalanche, Escalade, Suburban, Silverado, H2, Tahoe, Yukon and Denali)
This package is for the headers only with 2 1/2" collectors. Reducer cones have 02 sensor bungs installed. You will need to cut/weld these to your stock Y-pipe.
115-841300
SuperMaxx Stainless header System
$1294.99
115-841350
2000-'03 6.0 GM Truck / SUV SuperMaxx Stainless header System
$1294.99
115-841310
2000-'03 4.8, 5.3 6.0 GM Truck / SUV headers only (won't fit 2500 series)
$974.99
Tom
    hotfish
    hotfish
  • Who's Online   6 Members, 0 Anonymous, 839 Guests (See full list)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
