Rear defrost / defog fuse
slickman
I'm pulling my rear window which has the defrost element in it and I'm installing a slider. I'm not installing a defrost slider so I need to permanently remove the fuse. I think its fuse #10 in the fuse panel under the hood but I'm not sure.
I found its Fuse #10 and relay #69 which I pulled both. If I'm not correct please post.
