AC Blower Issue and Digital Climate Control Issue
Hey Guys,
Couple quick questions.
First question: About a year ago I replaced my blower resistor because the blower wasn't working at all. Now I have an issue that is intermittent - the blower will work fine, then shut off, and then I'm able to get it going again if I kick it really hard. Turning on or off the truck, blower, etc doesnt do anything, only kicking it works. When it is working, it all works correctly (all speeds work etc). At first I was thinking it was the motor itself, but after googling its sounding as if its the resistor again. Could it be the blower, or is this another classic resistor issue, even though I replaced it a year ago (I used the universal have to splice in from AutoZone type resistor). Whats to test to determine between the two?
My second question: When I try to turn the dial on my digital climate control to change the temperature it jumps all over - mostly when I try to turn the temp higher it will actually go lower - I have to go super slow and sometimes it seems like it helps if I push or pull on the knob as I turn. I assume I can just buy one off probably EBay and its a quick swap out? Are all years the same and is there anything I need to be aware of for swapping it out?
Thanks for any advice in advance.
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 309 Guests (See full list)
