Silverado, manual transfer case shifter stuck in cold weathe
2000 Silverado, manual transfer case shifter stuck in cold weather
Just turned 100.,000 miles, when it's gets down to 20-30 degree F range the 4X4 shift lever won't budge from 2WD to 4WD. After it runs for awhile it will usually engage but not always. When it doesn't, I need to put a space heater underneath the truck and let it warm up, that usually does the trick. Problem is...in the winter if I need to plow to get it in the garage, it's stuck in 2WD which is hard to plow in. Any ideas what problem I'm dealing with?
Thanks in advance
    appletrav
    appletrav
  • Who's Online   4 Members, 0 Anonymous, 628 Guests (See full list)
