Newbie from Minnesota "Oil pressure switch problems"
Hello folks.
I have a 2010 GMC Sierra with the 5.3.
Last winter I got bent over to the tune of $450.00 to replace my oil pressure sensor. Well exactly a year later and we have to do it again. I want to relocate this sensor. I made a new wire harness to do this. I made it 42 inches long. At first I was going to put the sensor above the oil filter by using a aftermarket block that goes to the oil cooler. I have a oil cooler as a option on my truck so that`s out the door. I could use a fitting from the original location and run a hose out into the open? Or lastly install the sensor in the rear oil galley plug. I read that plug is a 16 mm x 1.5, the same as the oil pressure sending unit. Magic right? But nobody has done this from what  I can find on the internet.
Advise?
 Thanks Joe
Have you replaced the lifter oil filter under the sensor? Pretty common to get plugged and people assume it is the oil pressure sensor.
Yes both were replace exactly one year ago. Oil changes at shorter intervals 2500 miles or every 3 months. I drive 22 Miles round trip to work each day and the truck gets to full operating temp.
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 705 Guests (See full list)
