NVG3500 5-Speed
Anyone else with the NVG3500 tranny have a problem with rattle and grinding noises. At low speeds it is very noisy. Also Theres a steady grinding type noise when in neutral at idle. And when I press in the clutch it stops. Then I let it out and it gets loud again. The dealership already said it was the bearings in the tranny so they replaced them all. Didn't do anything. Plus I don't like my service department so I havn't brough it back since. Just want to knwo if I'm the only one or if it's just a noisy tranny.
My NV-3500 and my Dad's both make some rattles, whining in 1st and 2nd and some syncro noise, but they only grind when we miss a shift. :cheers:
There is some gear rattle in nuetral that quits in about 5 seconds when you push in the clutch.
Compared to older 4 speeds the NV-3500 is downright smooth, slick and quiet, which is why we've never worried about them. They aren't near as refined as a Honda transaxel, but you don't need to worry about it.
My NV-3500 and my Dad's both make some rattles, whining in 1st and 2nd and some syncro noise, but they only grind when we miss a shift. :wtf:
Rodger that the 5spd are tons better than the 4spds of the 80's the syncros work and they stay in gear it's nice. Better gear spacing except between the dreaded 2nd to 3rd step. My NV4500 is rather loud too not to worry about it. But walk with your head higher because your are one of the few, the proud, the Men...I mean stick shifters... :wtf:
  • 3 weeks later...
I am always glad to hear there are others out there like me, you know, people who know what that third pedal is for! I love shiftin gears and burning the rears :chevy:
Anyway, I hear a little noise in neutral with my foot off the clutch and it goes away a few seconds after pushing in the clutch. I dont notice anything while in gear though and wouldnt think it was normal if I did.
I would like to add my problem to this thread though, sometimes when shifting into first gear at a stop sign if I am rolling very slow (1-4mph) or just stopped the shifter gets kicked back at me. It always seems a little tough to get into first gear compared to the other gears at least. I am guessing that the synchro for fist gear is worn? I was thinking about changing to some synthetic fluid also, any recomendations? I have taken to double clutching before downshifting to first at a stop, that makes the shift much smoother. I cant remember if this happens when sitting at a light in N then putting it in first, I think it does sometimes but overall its very rare.
no worries if I don't get my truck into first all the way it will push it out of 1st and 2nd sometimes. I just double clutch and tach the motor a little to help the synros' do their job. Seems that all are trucks have 1st and rev. problems with sticking in gear.
  • 5 months later...
I have been having the same problems in my 98. The noise is not loud in neutural, but it is when under load (starting form a stop) in 1st & 2nd gear. sometimes in 3rd if under heavy load, It's been doing this for a year & a half. Someone did tell me it's the clutch, but I'm sceptical.
d**n C1500 I have to say thats a mighty fine truck you got there . great engine / tranny combo too :thumbs:
Thanks K1500, :lol: But all I've done to it is paint the grill to match, & remove all the lables, When this engine goes, I'm thinking of putting a V8 in it.
Thanks K1500, :D But all I've done to it is paint the grill to match, & remove all the lables, When this engine goes, I'm thinking of putting a V8 in it.
You do realize my reasoning behind my last post dont you ? :lol::lol:
    bellssn690
    bellssn690
  • Who's Online   3 Members, 0 Anonymous, 636 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
