My buddy has a CJ with a cracked block. He can get a 4.3 motor pretty cheap, but he's worried about the wiring and electronics. Has anyone ever done a similar swap with a 4.3? Any references on the 'net?
Thanks,
Matt
Thanks. That settles the wiring. Now how about motor/tranny mounts, t-case, and driveshafts? Do you have to use the t-case from the V6 and then have new driveshafts made?
The 4.3 is one of my favorite motors. Good low-end grunt rev's and is willing to work. I've also heard alot of people putting 4.3 and 5.7s in their jeeps good swaps. Plus with a 4.3 liter if you blow it you can use the mounts to drop a 350 in.. :wtf:
  • 3 weeks later...
    hotfish
    hotfish
  • Who's Online   6 Members, 0 Anonymous, 839 Guests (See full list)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
