Truck Leveling Adjustment
Had my truck at the dealer yesterday. :cool: I knew a few days after I purchased it, it was not level. The driver side was lower than the passenger side, looking from the rear. The dealer tech determined it was out of spec. (duh...). They used the term "spring sag" as the problem. They opted to add a 1" spacer under the drivers side vs. replacing the spring. If the spring is sagging, doesn't that mean it's getting weaker? Isn't adding a spacer just a band aid? For those which have had this problem, please post what the dealer has done to resolve it.
Take it back and tell them that is a good temporary fix but when will my new set of springs be in! On my dads 2000 Z-71 he had a problem with the rear sagging bad when it was new. After several trips over there they finally realized it had 2WD springs on it. Go figure! They replaced both springs and been fine since. I had the springs replaced on my 97 Z-71 also when they started sagging at 50K miles with no problems. Take it back and have them replace the springs!
    appletrav
    appletrav
  • Who's Online   1 Member, 1 Anonymous, 467 Guests (See full list)
