Universal Remote to Homelink
Has anyone swapped their factory universal remote (learcar2u) transmitter for a homelink transmitter? my 2012 GMC Sierra SLT has the Universal Remote which is made by Lear and is their learcar2u system.  I had to replace my garage door opener and found out from the www.learcar2u.com website that this system is incompatible with the new opener and can not be programmed for it.  I also found out that GM stopped using this system in 2014 and all 2014 and newer models have the homelink transmitter, which works with modern garage door openers.  In looking at the illustrated parts breakdown, I was wondering if I could just swap the transmitter, which is about $100 part.
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 685 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
