2018 Suburban LT wireless charging - cable
I just bought a 2018 Suburban LT.  while it has the center console top that contains the tray for the phones to charge, I know it does not have the wireless module installed. I just ordered one and hope to have it in soon.
My question is.  When they build these do they use a general wiring harness and is it already there?  Or will I have to find a connector and then wire it in somewhere myself?
i know that it is a six pin connector, of which only three wires are installed, and only two do anything. 12 volts and ground.
i ordered a couple tools to help pop the inside of the console line to look but I’m still waiting.  Just gettin anxious here.
Grin
Robert
Grin
Robert
You might have more luck posting in the Suburban section.  This is the Silverado/Sierra section.  Here is a link.  Best of luck!
https://www.gm-trucks.com/forums/forum/191-2015-2019-tahoesuburbanyukon-mods/
    bellssn690
    bellssn690
  • Who's Online   3 Members, 1 Anonymous, 532 Guests (See full list)
