Need help installing electric fan
I bought the flex-a-lite 292 for my 03 Silverado with 28" wide radiator. The wiring directions are a little weird. Also I am trying to get the old fan off with the single big nut and having problems. After I do get it off and remove the fan, what should I do, go buy a big nut or put the fan clutch back on the end of the water pump without the fan? The directions kind of suck, needs more pics. I also don't like having to cut into the A/C wiring and somehow need to figure out which wire is the trigger wire and whether it is + or - . Probably call them tomorrow...
I think I found the answer to my question in Tbyrne's post about his install.
If anyone else is thinking about using these here are a few quick notes that will help your install.
The fan controller needs to be connected to a wire that is hot when the truck is keyed on and cold when it is off.
If you take the cover off of the fuse box under the hood and then lift up the cover that has the fuses in it you see 6 different sections. I used a wire in section 1 ( top left hand corner). Count two wires over from the right and 3 down.
You will find 2 wires here. I used the purple one on the right.
You also need to tap into the activation wire that goes to the clutch compressor for the AC.
There are two wires there. I used the green one. (I guess that's the positive wire.)
These tips should help you get through the install in a couple of hours.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,144 Guests (See full list)
