My Tahoe is in the shop.... :(
siume99
I took my truck into the dealership yesterday evening to check the parking brake.  They noticed that the "Y" adjuster was already tightened all the way.  By that time, I needed my truck for the next day (today)....and no rental.  So I took it back tonight.  Enterprise rental gave me the choice of a Ford Escort, or a Saturn.  Well I picked the Saturn (I at leasted wanted to stay GM).  Guess what.  It was nearly out of gas, and so was the Escort.  They wound up getting me a Toyota Corolla...........BASE MODEL!!!!!   :angry:  Can you get any further from a Tahoe LT?  I only drove the POS 2 miles so far.  50 miles round trip to work tomorrow and not another mile for it either.  I never knew how well I had it with my truck!
*EARLY WARNING* no offense to those offended by my following remarks.  There is a good reason for people to purchase these cars.  (can someone tell me.....other than they are cheap $$$?)
There is no tilt steering.  The steering wheel gets hit by my knees which are bent up because the seat is all the way back and needs another 5 inches!  Oh yeah....don't let me forget the accelerator.  It has decent get up and go, but my size 13's have about 1/4 inch of leeway before I'm on the brake.  The mirrors, you think they have a little knob on the inside to do the manual adjustment.  NO!  I have to push on the mirror.  Did I mention that I can easily palm the tires (width wise)?  I'd rather have motorcycle tires!!!
Thanks for listening to my venting.  I'm going to ask the dealer if it's possible for the rental car place to only handle GM cars/TRUCKS.
I feel for you man!!!   I was there too, when I had the Transfer case in my truck replaced.  I drove an F150 for 2 weeks, and then when the truck had to go in later for a few other related problems, I drove a base model Cavalier...
I hope you get your truck back soon.
Thanks Shaners
Gee....reading back on that, I really sound stupid.  :thumbs: I will have my truck back tomorrow evening.  It's not the dealership's problem, they are always great with me.  My salesperson/truck manager and the service people all know me by my first AND last name.  (It's not because I give them a hard time either!)  :D
I feel very vulnerable driving such a small car.  I honestly didn't notice how "powerful and protected" I felt driving a larger vehicle.
Well, half of my driving time is over...just another 25 miles.  I forgot to mention, it doesn't have cruise control.  I can keep my speed constant in my truck, but it is a challenge in such a cramped car with my legs crunched up. :thumbs:
I found out two things that are cool about the car.
1.  While upright, I can put my fingers on the passenger window. (It's a piece of cake to get papers or other things that slide off the seat.)
2.  I can actually see OVER the rear view mirror. :D
    ChristopherDobson
    ChristopherDobson
  • Who's Online   0 Members, 0 Anonymous, 1,208 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
