Avatar
Yont283
My picture is always blurry in the avatar, do you have to have a special picture or what? How do you make it unblurry??  ???
It's trying to squish it into the correct size.  If I remember correctly, the max is 64x64.  It should tell on the page where you edit the avatar.  Just resize it so that the biggest side, either width or height, is 64 pixels.  The shorter side will probably be less.  If you do both width and height 64x64, it will still squish it.
Does that make sense?  ???
The max size is actually 100x100. At least it is now. Do you resize the picture using Photoeditor to make it fit or what?  ???
Ok, 100x100.  I couldn't remember.  I think it used to be 64x64 then.
Yeah, I think I used paintshop pro or photoshop.
For example, if the original size is 500x331, jsut use the resize option, make sure it maintains the aspect ratio, and resize it to 100x66.  It will keep everything in proportion.
If you need any help, let me know.  Or if you want me to do it, just e-mail or pm me the original sized picture.  :thumbs:
    Patrick Fergy
    Patrick Fergy
  • Who's Online   1 Member, 0 Anonymous, 1,295 Guests (See full list)
