So I've got an issue with my passenger side rear lighting and I'm really stumped as to what's going on. The turning lamps function, the brake lamps function, the reverse lamp functions--everything works EXCEPT for the tail/running lamps.
I thought it might be an issue with the bulbs, so I ordered new ones, installed them, and still no fix. At least from what I looked at, the connections look good as far as the individual bulb sockets are concerned. I also checked the interior driver side fuse box and the fuse box under the hood to see if any fuses were shot, but I was a bit confused as to which fuse I was actually looking for. In the section in the manual that tells you how to swap the bulbs for this tail light housing, it calls them "taillamps, turn signal lamps, and stoplamps," but when I go to look at the fuse diagram, nothing is labeled with those terms.
I ended up just pulling and checking any fuse that I thought might possibly be the culprit, but they were all intact.
Anyone familiar with this issue/have any suggestions as to a fix? It's a rather frustrating issue, and of course I have to get inspected this month.
Thanks!
  • 3 years later...
I am having a similar issue where my running lights are not working on passenger tail light. Brake lights and turn signal works just fine. When I take my key out and there is a minute of lights being on everything works. I replaced the wiring harness as I saw this was a common issue but the same thing is still happening. I am thinking it is the actual connector the wiring harness is going into.
    Whit.the.COB
    Whit.the.COB
  • Who's Online   1 Member, 0 Anonymous, 1,146 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
