1999 Sierra 1500 4.8 ABS Module
Hey Guys I need some help.
I have a 1999 GMC sierra with an abs issue, It all started with the pump running 24/7. so I pulled out the old module and swapped it with one I found
at the scrap yard it was in great shape, It came out of a 2002 Silverado. Which I assumed to be the same being a GM.
The pump is no longer running but the abs light remained on and now the truck will start and die Immediately, if I unplug the module under the truck. It seems to run just fine.
I have read a few different forums, Some say the module needs to be reprogrammed at a dealer ? what do you Guys think.
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 685 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
