Hail Damage on S10
VicRed
We had a hail storm last night and my old S10 that I was just about to sell suffered some damage.
I was wondering how hard is it to perform the paintless dent repair yourself?
I have mechanical experience, but really no experience with bodywork.
Any help is appreciated!
Depending on where the dents are located.  Some of the places on the hood would be fairly easy as long as it isn't under one of the braces.  The roof would be a PITA.  Will have to remove the headliner.  It has been quite a while since I have torn into an S10.  Can't remeber how large of an access hole is in the roof.  The bed rails will be a PITA.  The double wall design really prevents you from getting to some areas easily.  If you can get to the dents easliy just work slowly and don't overstress the metal.   Good luck if you plan to tackle the project.  :D
I had an over the rail bedliner so there is no damage to the bed rails.  There are dents in the roof and the hood.
Thanks for the information.  Do you have any suggestions on where to buy the tools to do it?
Thanks.
You can probably get a cheapie set of hammers and ding dollies from someone like Autozone or online from Northern Tool.  Cost around $20 per set.
Northern Tool
I got a set of hammers and dollies from Eastwood several years ago for my resto shop.  I made a few tools in the machine shop so I could do real hard to reach places before commercially available tools were available.  The commercial PDR tools would be pretty expensive for what you are wanting to do.  Hammer and dollies are probably your best bet.  Keep in mind that you will have to have a second body to help you out with some of these dents in the hood and roof.  Do you have any pics of the damage?
    ChristopherDobson
    ChristopherDobson
  • Who's Online   0 Members, 0 Anonymous, 1,207 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
