Hello everyone,
I have searched the forums and could not find the answer to my specific issue so i am hoping someone can chime in and give me some other ideas on how to get my sunroof working.
I purchased the truck and the sunroof never opened and here is what conclusions i have come to and what i have done so far to try to get it working.
1. There is power at the switch
2.There was no power at the motor so i replaced the sunroof module (PN 1038812) - There is now power at the sunroof motor
3. I push the sunroof switch and the motor will turn in one direction but it does nothing in the other direction (motor is connected to the harness but not installed on the track currently)
4. So i know the motor works but when it is reinstalled on to the track it wont open the window
5.I manually powered the terminals to get the motor to turn in the opposite direction and it did turn, so i know the motor is not ceased in anyway.
6. I Also purchased a new sunroof switch (PN10381806)  and it had no new affect on the motor direction
7. I have removed the battery and motor still only operates in one direction
Is this normal that the motor would only spin in one direction? could it be possible the track is simple ceased?
Any info would be greatly appreciated!
thanks
  • 5 years later...
    bellssn690
    bellssn690
  • Who's Online   3 Members, 0 Anonymous, 706 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
