Changing Transmission filter
I know its been discussed before but what are the basic steps in changing the transmission filter? Is it more trouble than its worth or is it pretty easy to do yourself. Do you have to put about 4 qts of fluid back in afterwards?
99 w\5.3
Changing the trans filter is not that bad of a job. You will need to remove the shift cable and bracket to access the bolts on the drivers side. The shift linkage pops right off and you will need a torx bit to remove the two screws for the bracket. Other than that,it's just a matter of loosening all the bolt and draining the fluid. The drain plug on my truck was in so tight I couldn't loosen it. I believe the filter is held in by one bolt and it comes right out. Piece of cake! :jester: 99 sierra 4.8L
just for safety
make sure you have the truck securely chocked
since you will be messing with the shift cable it is
very easy for it to slip out of gear and roll right over you
BTW --not good
you really only have to remove one of the torx screws
and the hanger will then pivot to the side to allow access
i did not have a torx so i took a pair of channel locks
and grabbed the side of the bolt and untightened it
mine did not have a bolt holding the filter in
it just popped out of the bushing it was in
you can change out the bushing to the new one --BUT--
it is a total pain and you better have the right tool to grab it
or you will scratch up the valve body
i personally left the old one in and just snapped the new filter
in place ( i'm comfortable with it)
again total job about 90 minutes which includes giving the pan a good
cleaning
:jester::lol::D
silveradoW
if i remember right
the shift cable is on the passenger side of the tranny
and the two torx bolts are on the driver side
but i can't remeber exactly
check again and if you can't find them i'll get under the truck and see
:jester:
silveradoW
if i remember right
:jester:
I think something is blocking me on the drivers side? But cant get to anything with that front driveshaft there. I'll look next time I change oil, I still have about 6000 miles before I change the trans filter and fluid. THANKS
A GMC dealer in the Dallas area charges $105 to change the trans filter or $125 to do a trans flush. I had them do the flush and probably will do the filter myself later.
Depends on your cash situation. For me, $160 is way too much and I would rather do it myself anyhow and know it's done right.
The shift cable is on the driver's side. Find the tranny pan. Look to the driver side and you should see the shift cable. The shift cable attatches to the tranny from above. Meaning you slide your hand up between the tranny and chassis, point the 1/4 inch socket with torx bit (what I used) down towards you laying on your back. The goot news is, once you crack them, they should be easy to spin out. Once you remove the bracket, drain the pan (careful with that soft drain bolt), remove the pan bolts, and carefully remove pan. I had to work mine around the crossover pipe. It's tight but is does come out and I have the oem deep pan. Replace or re-use the gasket.
Hardest park IMO is getting the old filter seal out. I used an awl between the sleeve and the seal to bend it i enough to grab with a pair of needle nosed pliers.
Good luck.
filter and gasket from advance auto less than 10.00
4 quarts of .99 atf
total job cost less than 15 bucks
left in wallet = 145.00
WE GOIN SIZZLER
WE GOIN SIZZLER ~!!!!
:jester:
I was going to do it myself also, but saw a coupon (about a month ago) for Cottman Transmission for a transmission service for $19.95 (fluid and new gasket). Called them up and asked if I could supply the new filter. They said "no problem". Glad they did it. They had to loosen the exhaust pipes at the exhaust manifold to get the pan off. Had a hard time later getting it sealed off after changing everything. Took it back once for them to tighten up a little more on the manifold doughnut gasket. Been great ever since. That was a little over a month ago with no problems. :jester:
When you change the filter and fluid yourself you are leaving lots of dirty fluid in there. The trans cooler, lines and torque converter still have dirty fluid in them. A flush is the way to go but, $160 seems a bit steep. In my area you can get it done for around $100.
I like flushing. First, it is not a backflush. The fluid circulates the same way as normal so it won't dislodge anything from the filter.
I alternate between flush and filter change.
25K Change filter and fluid, drain and refill fluid 1 week later. This gets most of the fluid replaced.
50K flush
75K change filter and fluid, drain and fill fluid 1 week later.
100K flush.....etc
I've got 108K on the stock tranny so far and all is well. That includes towing and abusing.
    ballencd
    ballencd
  • Who's Online   3 Members, 0 Anonymous, 428 Guests (See full list)
