Bed Removal
I have a stepside bed and need to take it off to replace the fuel pump. How do I disconnect the fill tube and where are the electrical connections at?
Thanks!
:mad:
the easiest way is to take the filler neck flange loose from the bed side. It only has 2 or 3 bolts with torx head if I remember correctly. The electrical connectors are near the rear of the bed on a sort of connector center. Be sure to remove the grounding strap that runs from the bed near the fillerneck to the frame (also be sure to replace this).
