Brakes, Brakes and more Brakes
Hey fellas,
Havin' some trouble with 94' Silverado brakes. The shake has gotten worse, and now there is a whine when I brake and it pulls hard to passenger side. I've pretty much narrowed it down to rotors or calipers (instead of front end), but I wasn't sure which to try. I'd never heard of rotors causing a pull to one side, but could be I spose. The rotors have been turned twice in 162k miles. The whine is louder when braking into turns. Sounds like calipers to me. Anyone?
I would say it is your brake pads that are squeaking and the rotors are probably warped. At least I would pull a wheel off and see what the pads look like and go from there.
ok...heres what I've been told. I called a few auto-part stores and they told me than on late model Bow-Ties they have a tendency to wear the hoses out. He said to look for a redish color brake dust (indicates heat I guess). He said what happens is fluid will pass through the hose into the caliper, but won't flow back. The causes the caliper to lock, and eventually wear completely out. Said it'd be obvious once I got the tire off. Cheapest prices were $49.99 for rotors and $12.99 with a $35.00 core on the calipers. Figured I'd replace the fluid too while I was puttin' new parts in it. He said that with 162k (rotors been turned twice already and are most likely warped) that I might wanna consider replacing both. After I do that, check for same pull...then I'd know it was the hose.
I just had it alligned about 5k or so ago, so I highly doubt that its out of allignment. Is there any place I can go that will do free alignment/front end checks? I'd like to check the front end out (ball joints), but I'm not sure what symptoms to look for with worn ball joints. Fluid? Discoloration?
    bellssn690
    bellssn690
  • Who's Online   1 Member, 0 Anonymous, 706 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
