Power plant swap
Ok. I'm new here. I have a 2000 Silverado with a 4l60e and a 4.8 that i want to swap it out for a 5.3 and a 4l60e that I found. Does anyone know if an 02 engine and tranny with all the wiring and computer will fit for a power plant swap or no?
    bellssn690
    bellssn690
  • Who's Online   4 Members, 2 Anonymous, 831 Guests (See full list)
