2017 Sierra 2500 Denali Vibration
I recently purchased a 2017 Sierra 2500 Denali, 4x4 with 55K miles on it.  The CarFax said that the driver front axle was replaced by the original owner in the 20K-30K mile range, and then the passenger side was replaced by the dealership when it was traded in.  Dealer told me they did it because the CV boot was torn, so they replaced the entire axle.   I have had the truck for a week now and have noticed a vibration in the floorboards and gas pedal while under acceleration, almost like I can feel the driveshaft spinning.  It's noticeable enough for concern.  Also, 4x4 high makes a horrible whine starting at about 30 mph while trans is under load, both accelerating and decelerating.  Sounds like a turbo whine almost.  Dealer said it's a bearing in the transfer case and will repair it for me... still waiting on back ordered parts.
All of this got me thinking, so I started investigating.  My first was the clue was the Tough Country shocks on the front, which made me think this thing was probably lifted or leveled.  So I measured the fenders and both front and back measure 42.5 inches.  I cannot see how this thing was leveled...maybe torsion bars are turned.  Everything in the wheel well apear to be stock (besides the shocks).
Question is... can a lift or level be causing the vibration I am feeling and 4x4 noise?  The vibration in 2wd is alarming and has me worried I'm doing damage every mile I drive.
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 451 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
