Headache Rack lights
I want to put two small leds on a headache rack on my 2020 Sierra. Should I try and connect to tail lights or trailer plug lights or will that throw a code or cause problems?  Should I use a fuse tap under hood like people do for the raptor style grill lights on parking  light fuse?
