Help with rocker switch panel wiring
I am wanting to install several different aftermarket modifications to my truck. The modifications being led lights, backup camera, etc. I would like to use a rocker switch panel instead of wiring each individually. My question is do I need to set up an independent fuse box for this, set up a fuse for each, or only a relay? What is the easiest way to go about this? I hope this makes sense. I am definitely very new when it comes to wiring, but definitely trying to learn. Thanks for any and all help given!
I had to rewire my 82 Eagle SX4's lighting back in the early 90's.   Wiring was a mystery on cars then.  So I ripped it all out and did it my way.  Fuse and relay each one on its one line, and make a Good ground for each.   It worked for many years then I garaged it.  They all worked still after a 10 year sit.   Just watch out if it has an effect on something to do that, computers don' t like messed with.
Thanks so much! I'm sure thinking about doing it just like this. Building a fuse/relay box is looking mighty expensive!! Thanks again for the help!
    bellssn690
    bellssn690
  • Who's Online   3 Members, 0 Anonymous, 905 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
