I always wanted to snorkel for my truck so I started to look online on eBay to look for universal snorkel kits the only thing I could do is find some pictures that had measurements and the appropriate designs and angles for the fenders and for the mounting locations. I ended up choosing a 1988 defender snorkel kit. Cost me $165 with shipping.KIMG2170.thumb.JPG.3e487ac59b1f10131f33df20bd48a1c7.JPG
Edited by Mudz
Pictures no upload
Always wanted to snorkel in my truck went to eBay on a 1988 defender universal snorkel with some pictures that had some measurements and contours that reflected the mounting locations and shapes of the vehicle.The hardest part was taking a three and a half inch hole hog and plowing a hole in the side of my fender.
Edited by Mudz
Pictures
    DaleB
    DaleB
  • Who's Online   3 Members, 0 Anonymous, 1,060 Guests (See full list)
