19-20 Silverado DRL Relocate Harness for Halogen Headlight Models
$220 OBO (free shipping)
Only used on truck for approx. 2 months.
This harness is for those with 2019-2020 new body style Silverado's that would like to disable their headlights as their DRL's and instead use the front side marker as their DRL.  In auto mode this harness will allow, for only your front side markers to be on during the day,  This is very useful when going to either LED or HID low beam bulbs.  Light will operate as normal at night.  This harness is only for those with 19-20 new body style Silverado's that are equipped with the base, halogen style headlights.
  • 6 months later...
I need this exact harness for my spider headlights that have the white halo accents. I want the accents to act as my DRL's instead of my low beams. I was going to buy directly from Gen5DIY but might buy from you if i can? My email address is: [email protected]
Edited by Jonnynorway777
pictures to show what i mean, I want my black truck's headlights to act as the ones on the white truck
  • 2 years later...
To answer your question.The gen5diy harness worked on my aftermarket headlights.The planked lights worked as drl.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   2 Members, 0 Anonymous, 1,087 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
