dash lights
got my truck inspected and when i got it back the dash lights were out the fuse is good . i have a problem a little bit ago with the dash lights going out while i was driveing but that went a way do u guys think it could be the dimmer box
Here is a stupid answer because you probably already checked, but make sure that the dimmer is turned up. Once took the dash apart and must have rolled the dimmer down. After putting it back together it had no dash lights. Did figure it out though after five minutes wondering what I did wrong.
Yes I can almost guarantee you that it is your dimmer switch.
I had mine replaced and I got the dash lights back on. Check to
see if the dash lights are the only ones that are off. Because if your
window switch lights are still on, then it means that you have a problem with your Dimmer switch.
thanks guys i found the problem the power wire to the dimmer box was fried and it must have shorted the box out because only my drl were workinf so i riged it for now. do any of you guys now thw part number for the dimmer boxand i also need the part number for the heater ac controls thanks again guys
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,218 Guests (See full list)
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
