I'm getting tried of canceling the service  suspension light so I want to get this figured out.  I have Bilstein shocks and struts on all for corners now, I also installed the resistors on all 4 corners where the magnarides were plugged in.  After about a year the light came back.  I replaced one resistor and tested/swapped the other three with new ones but I still have the light.  I'm thinking it's a level sensor now. Truck is a 2015 Denali.
Does anyone know if Shocksims still sells the 8 piece kit or is it just the OBD kit?  I have an email into them but hoping to get some more testing in this week.
Is there an app I can diagnose the suspension system with to see what the truck is reading?  Maybe do a relearn.  A GM version of AlphaOBD.
I have enough resistors to wire into the level sensors but I have not seen anyone say how to wire the three wires.  Anyone know where to get the info from?
 Level sensors are cheap enough but I just don't know which one it could be.  Anyway to test them?  Also, I don't particularly care for our dealerships here and getting them to do odd things like a relearn is like pulling teeth.
Edited by B88i45
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 630 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
