Hope I am posting in the right spot?
Curious I looked at 2021 Trail boss stated no AFM   This was just in parking area (Not open today)
The 5.3 without AFM do they still come with the AFM lifters?  Curious as internals of the NON AFM?
Did they just "turn off" because of chip shortage and keep all AFM junk inside?
All the internal AFM parts are still inside the motor. Due to the chip shortage-there just isn't the controls to activate the "feature".
On 6/2/2021 at 1:00 AM, newdude said:
Yep parts are in the engine, ECM is missing the control features.
That's too bad. Hope that the shortage would end.
    DaleB
    DaleB
  • Who's Online   4 Members, 0 Anonymous, 1,414 Guests (See full list)
