I have a 2015 Silverado with the 5.3 and the last time I got gas I reset the best mpg for 25, 50 and 400 miles and in the past it resets to the middle on average and the best shows two dashes for awhile then starts showing numbers but I’m at nearly 200 miles since I put gas in it and the best still shows two dashes for all miles where it should at least show for the 25 and 50 miles. Any help would be great.
    Dom Colussi
    Dom Colussi
  • Who's Online   4 Members, 0 Anonymous, 693 Guests (See full list)
