I saw on the internet that there is "tailgate cap" lighting system avilable for Ford pickup trucks, I think it was for the F150.  Is there such a item for the 2021 Chevrolet Colorado, I really do not want the strip that is below the tailgate.  I would like something a bit different.
    Dom Colussi
    Dom Colussi
  • Who's Online   4 Members, 1 Anonymous, 591 Guests (See full list)
    • *Your
    • I'd guess that it's because they are Mann-Hummel filters since about 2016, they own Wix and are mostly all made in China now.
