Alright, so I accidentally popped out my cap/plug for where the integrated trailer brake controller would be if i had that equipped on my 2020 LT Trail Boss. It's just a faceplate plug with no functionality. While i have the plug popped out and i have the cable accessible, has anyone done any mods to this part of the truck? i'm looking for ideas here before i decide to buy a new faceplate plug and put it back in.
i attached a cord holder to the exterior of the blank plug with some gorilla glue. since i'm transitioning to wireless android auto, i removed the cord holder and then was working the gorilla glue excess off with some nail polish remover when apparently i pushed to hard on the plug and it popped off inside the housing. i'm a bit shocked that the plug popped inside relatively easily but then again maybe it's not as shocking
    DaleB
    DaleB
  • Who's Online   1 Member, 0 Anonymous, 1,206 Guests (See full list)
