Has any one heard of issues with 2019 canyon catching fire with no explantion. Mine caught fire while parked outside my house. I have heard nothing from my call to gm customer service
  • 3 months later...
    DaleB
    DaleB
  • Who's Online   3 Members, 0 Anonymous, 1,184 Guests (See full list)
