Has any one heard of issues with 2019 canyon catching fire with no explantion. Mine caught fire while parked outside my house. I have heard nothing from my call to gm customer service
  • 3 months later...
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 1,140 Guests (See full list)
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
