Hi guys, I have recently just bought a 2005 sierra 1500 that needed a new trans. I replaced the trans and now I have no speedometer and the truck won’t get out of first gear. I also have abs lights that have been on the whole time I’ve owned the truck. C0550 and c0055. I replaced the (vss) vehicle speed sensor but it didn’t fix the issue. Any ideas would be super helpful thanks!
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,218 Guests (See full list)
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
