So today I started the truck, codes popped up truck and showed limp mode. When I drove it it vibrated truck. Stopped and shut truck down then restarted and it was fine but of course had engine light. I pulled codes and there was several.  I have no plans of going back to dealer unless it continues. Curious if anyone has had this on their 3.0.  8,800 miles no issues till today.
The P0205 and P0305 are directly related. Very possible that the electrical issue with that injector comes back and it begins to misfire again.
    DaleB
    DaleB
  • Who's Online   4 Members, 0 Anonymous, 1,414 Guests (See full list)
