Looking for some guidance on this issue, I parked my truck for 5-6 days while away on vacation and walked up to it today and the keyless entry didn't work. I thought I might have killed the battery so I got in and sure enough the battery gauge was showing it was dead (or so I thought). I tried to start it and it was cranking over strong for 2-3 seconds and then just dies like it doesn't have fuel.
I got home and checked the battery and it has 12.25 volts, I tried hooking up my code reader to see if it was a position sensor that failed but the reader says no communication to the ECM. So I jumped in and all the gauges just flicker up to the bottom of the sweep so the battery shows as dead but has 12 v at it, fuel reads empty but I have over half a tank at least, the windows will not work and the power locks are also not working. I've had issues with neutral safety switches in old C10's that I've owned so I tried to shift into neutral to start it but the cluster shows all the gears but when you shift it to neutral or any other gear it doesn't show you what gear you are in (if that makes sense.
Seems like a lot of things to go bad all at once so hoping I can get some direction to go in.. Is there a common fuse or ground I should be checking?
Fuel pump was replaced 4-5 years ago and very little mileage since then, 2-3 month old battery after being off the road over the winter, has an aftermarket Compustar 1-way alarm installed by a good audio shop and has been in there for 10+ years with no issues.
    Greg3160
    Greg3160
  • Who's Online   1 Member, 0 Anonymous, 491 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
