So I replace my front rotors with new rotors, that I cross-referenced my VIN number with. Check out the photo below for reference. They drag on the caliper. Has anyone experienced this?  The calipers don't float or have slide pins as you know, so the caliper just sits stationary in that position.
Any ideas?
Anyone hear of this being an issue with the trucks?  I had some odd wear on the rotors I removed. That's why I swapped them to begin with. Not indentations like you would get from worn pads, but almost like two raised lines.
Is it possible these rotors are slightly out of spec and they're supposed to sit that close to the edge of the caliper body?
Thanks for any help and input.
