I'm looking to replace my steering wheel in my truck its pretty beet up. I have a 2104 sierra Leather wrapped no heat . Has cruise control arrow keys and the buttons behind for radio control. From what I can find I think I need part#(84483756) but I'm not sure if that comes with all the buttons or if I have to swap my buttons to the new wheel. Any help would be greatly appreciated.
    • *Your
    • I'd guess that it's because they are Mann-Hummel filters since about 2016, they own Wix and are mostly all made in China now.
