Hey guys. This topic may have been discussed already but I need some help. I bought Phil’s 16 pin harness and green and brown usb cables. However I’ve installed an aftermarket radio that includes CarPlay via a usb attachment that came with the radio. That radio via the usb port uses the  2 12 volt wires coming from the dash that powered the cigarette lighter and 110 outlet. I guess I’m trying to figure out how do I wire this console to where everything works with the after market radio. I’ve included pics as well of the new console. And yes I know I don’t have the exact same trim plate that Phil has on the YouTube video. I just want to know can it be done is all. Thx in advance for your help to me on this…
