Oh d**n...
pacodiablo
We have freezing rain outside...not cool. Last time we got freezing rain the power went out for two weeks. I really hope we don't have another bad ice storm.
Its not cold enough to freeze here but it is storming bad. Just to be safe my computer is running off the battery for a while now.
At least you don't have to drive to work in it.....or at all. :cheers:
Sorry, I couldn't resist.....I never can. :cheers:
Hmm.....That actually sounds entertaining.
We're supposed to get up to a whole inch of accumulation tonight :cheers:
I might have to go sit by an overpass and watch. :cheers:
You guys must be getting the storm that came through Colorado the other day...
Amazing how drivers go from smart to idiot all with the change of the weather.....
Was talking to a cop last time it snowed (he came in as a customer). I asked if there were a lot of people driving stupid in the snow. His reply "We don't need snow for people to be driving stupid". Had a little laugh at that.
What I don't get is that we live in the Northeast, snow in the winter is inevitable, and we get it EVERY year, and at least one decent sized storm every year, however people STILL forget how to drive in the snow and we have A LOT of accidents the first snowfall we get. It's not like we all live in Florida and we're driving vehicles with summer-only tires on them in the snow. We have ALL-SEASON tires!
You have yuppies on your front lawn? :rolleyes:
Most of us have gnomes.
Actually, they are gnomes, I just painted business suits on them.
I used to have ghetto gnomes, but the NAACP got after me. :cheers::cheers:
    DaleB
    DaleB
  • Who's Online   2 Members, 0 Anonymous, 1,211 Guests (See full list)
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
